Sometime ago I "refinished" the rear leaf spring on my 69 (cleaned, repainted and replaced liners). Now I'm trying to install it and attach to my trailing arms (rebuilt by Bairs). I've attach the spring to the differential with the original mount plate and bolts. Per the AIM I torqued those bolts. I've since read posts by Joe Lucia and others not to torqued those bolts at this stage. Who's right?
At this point I saw that the spring link bolt hole in the TA didn't wasn't vertically aligned (front to rear) with the cushion cup hole in the spring. Just to see if the holes would align after raising the spring to installation position, I "completed" installation of the right side. You can see in the attached photos that the spring hole is 1/2" or more to the rear.
Another photo is of the unattached left side. You can see the misalignment exists on that side as well.
I took care to be sure the leaf spring center bolt is in the hole on the bottom of the differential. There doesn't appear to be any latitude here for front to rear movement. The differential wasn't removed.
Should I loosen the mount plate bolts, as well as any other previously torqued bolts? I previously left the camber bolt nuts finger tight. Any other suggestions?
Mike
Mike
