'63 Exhaust Manifolds Black After Test Drive - NCRS Discussion Boards
  • Frederick H.
    • August 31, 1983
    • 398
    Took the car around the neighborhood for it's first test drive after leaving the shop and the exhaust manifolds are turning black on both sides. The shop set the valves to factory specs but the engine was rebuilt back in '89 and I did not get a blueprint to get the cam specs (engine was bored .30), so not sure it's the factory cam. Running combination of 93 unleaded and 92 unleaded without ethanol. I expect the orange paint to burn off but never have seen them this dark - they were natural finish with regular drives on the weekends before the motor was pulled for paint and body and other mechanical work - about 2 years). I haven't had time to check the timing but it starts and runs fine.
    Thanks in advance for the help.
    Fred
  • Loren L.
    • April 30, 1976
    • 4104
    Re: '63 Exhaust Manifolds Black After Test Drive
    Looks to me like they're turning cast iron, which is exactly what I would expect.
    • Frank D.
      • December 27, 2007
      • 2703
      Exactly what I was thinking.
      • Bill M.
        • 1317
        Years ago after wire wheeling my manifolds back to natural look I read to spray WD 40 on the hot manifolds to keep the natural look. I do it every couple of months it helps keep the natural cast iron looking pretty good.
        • Jaime G.
          • April 1, 1988
          • 480
          they look fine to me. Whats the issue?
          • Frederick H.
            • August 31, 1983
            • 398
            Okay - maybe I just worry too much - they just looked a lot darker than they had before. Thanks for the reassurance - need all I can get.
            • Frank D.
              • December 27, 2007
              • 2703
              The same thing happens to painted iron manifolds at the intake heat runners (eventually)...
              • Michael G.
                • November 12, 2008
                • 2155
                Remaining carbon from the burnt paint probably makes them a bit darker than the casting was.
                • Frederick H.
                  • August 31, 1983
                  • 398
                  That makes sense Mike - thanks!
                  • Frederick H.
                    • August 31, 1983
                    • 398
                    Thanks Frank - guess I need to brush up on my chemistry and a little metallurgy - heat, paint, metal.
