I'm fighting problems in two 63's. This is the last one in the coupe.
I back up and hit the brake and I get a clunk. It only happens one time. I go forward and hit the brake and I get a clunk. Again it only happens one time. If I back up, I get it one time again.
I've replaced the front differential carrier bracket and rubber cushion. The old bracket looked ok, but one could debate if it was bad.
I've tightened every bolt I could find. I'll look at the rear brakes next, a suggestion from a friend. It has to be something that is being reset depending on direction.
Any suggestions.
Any suggestions.
