Driveshaft nomenclature - NCRS Discussion Boards
  • Gary B.
    • February 1, 1997
    • 6979
    Re: Driveshaft nomenclature
    Originally posted by Gary Beaupre (28818)
    Can someone confirm for me that the components that are welded onto the ends of the driveshaft that hold the u-joints are referred to as “yokes”?
    Gary
    Gary-----
    That's what they're called.
    • Gary B.
      • February 1, 1997
      • 6979
      Thanks Joe.
      I have one more driveshaft-related question. Was GM #3849500 ever a Corvette production line U-joint?
      Gary
      • Ray K.
        • July 31, 1985
        • 369
        Gary,
        In Spicer Driveline terminology they are called " Tube Yokes' but many also refer to them as " Weld Yokes"
        Ray
        • Gary B.
          • February 1, 1997
          • 6979
            Thanks Joe.
            Gary
            Gary------
            It very likely was but I cannot say for certain. In PRODUCTION, driveshafts (and half shafts) were supplied as an assembly which included the u-joints. So, without the GM drawing for the assembly, we have no way of knowing now what the part number(s) of the installed u-joint was. However, it was very likely the same as the SERVICE u-joint cataloged at the time. It could also be that the SERVICE u-joint was one of several that were optionally specified for the PRODUCTION assembly, the others never having been available in SERVICE.
            • Gary B.
              • February 1, 1997
              • 6979
              Thanks Joe.
              • David B.
                • March 1, 1980
                • 687
                As mentioned yoke came as an assembly. C1 & c2s were manufactured by Saginaw Steering Gear Division it was considered a "Proprietary Design" their print # for 56-57 was #5670052 called "Yoke - Prop Shaft Slip". The machine drawing #3712380 was called Yoke - Universal Joint Front.
                For "63 #3818917 Yoke - "U" Joint Front T-10
                "63-66 #3868727 Yoke - Universal Joint Front Muncie
                Too Many to list for rear etc. etc.
