Need Picture of '63 Front Differential Carrier Bracket - NCRS Discussion Boards
  • Norm B.
    • 360
    Golf is for those who can't play​ hockey.
  • Harry S.
    • July 31, 2002
    • 5258
    Re: Need Picture of '63 Front Differential Carrier Bracket
    That's over the top $$$. you can take yours and drill the two holes, add the clip, bolt, washer and nut. Yours has the added extra washers for strength, keep those.
    The one on eBay is a real 63 bracket, but, if those holes come out of round you will not like the noise you get.
    • Alan D.
      • January 1, 2005
      • 2027
      Or better still purchase the 64 bracket for $60 and drill holes in it, paint and you are all set for judging. It to is on ebay.
      Keep yours for driving around.
      • Norm B.
        • 360
        Thanks guys. It never crossed my mind the check E Bay for pictures. I was only expecting to see one hole but since this car will never be judged it looks like I will be drilling a couple of holes in the one I have. I think I will wait though until I have the clip in my hand.
        • Richard G.
          • July 31, 1984
          • 1715
          Here is a picture of a factory piece.
          I hadn't replaced the bolt when the picture was taken.
          Rick
          • Harry S.
            • July 31, 2002
            • 5258
            The clip is on the cable in Richards picture. The tip goes in one hole and the bolt, washer and nut occupy the other.
            • Norm B.
              • 360
              I see why there is two holes now.
              • Frank D.
                • December 27, 2007
                • 2703
                Originally posted by Harry Sadlock (38513)
                https://www.ebay.com/itm/Original-GM...oAAOxySoJTWtdO
                Yup - its not worth it; I'm running my original 63 bracket but have a reinforced one on the shelf should I ever need it....
                The TSB concerning the reinforcements is attached.
                • Tom D.
                  • September 30, 1981
                  • 2126
                  When were two front bolts changed to a single "through" bolt? Would that be in a 1963 or 1964 A.I.M.?
                  Was there an interim period in which the front bolt used a castle nut?
                  https://MichiganNCRS.org
                  Michigan Chapter
                  Tom Dingman
                    Tom-----
                    The forward bolts were changed to a through bolt for the 1965 model year. This bolt was retained with a slotted nut and cotter pin.
