How is the plastic tip on the inner cable for the tach put on? The end that goes into the tach on a 1961 Is it glued heated and slid on. Paragon feels it is the way I have routed it under the dash. It done as to there catalog and the AIM If i have to I will take care of this myself. I like to putter on things like this so I will play for a while. Thank You Fred
Tach cable
Tags: None
- Top
Re: Tach cable
Hi Mr. Ray Thank You for you fast reply. What would I type in under Archives to get Mr Olson.I look at the posting 2 times a day. However that is a on used area for me Thank You again Fred- Top
Re: Tach cable
Fred, I think this is the thread Joe is referring to.... Rich
https://www.forums.ncrs.org/showthre...ighlight=cable- Top
