The throttle on my 64 AFB carburetor will only open 1 3/4 inches with the linkage attached but 2 1/2 inches with the linkage removed. This prevents the carburetor from achieving full throttle and opening the secondarys. I replaced all the accelerator linkage except the accelerator lever which I was unable to access. I had the mechanic at the local Chevy Dealership, who was around when these cars were still in their earlier years and certified on these cars look at the problem. He could not find any adjustments on the carb linkage that would allow an increase in the throttle travel. This implies the accelerator lever is the culprit. I saw on another thread that the accelerator lever should just about touch the firewall when the gas pedal is pressed to the floor. Mine is around 2" away from the firewall with the gas pedal full depressed.
I tried to access the lever mounting bolt thru the engine compartment as well as the interior transmission tunnel but still couldn't get to the bolt. Is there any way to access the lever mounting bolt without removing the transmission? Is there even an adjustment on the lever mount or is it a fixed mount position?
I don't hot rod the car but I want it right. Any insight would be greatly appreciated.
