Gary
Lubing bolts before torquing
Re: Lubing bolts before torquing
Unless GM explicitly calls out lubrication, I would make the assumption the bolts are to be torqued dry.
If you do decide to lubricate the threads anyway, just be aware that doing so REDUCES the torque value to which the fasteners are to be tightened. The amount of reduction is difficult to predict and is a function of the type of lubrication employed.- Top
Many years ago, I read that lubing of bolts that torqued is applied to allows excess torque to be applied since the oil adds some "slipperiness". I don't recall if it was in The Restorer or some other forum but I do recall that, unless specified, bolts are dry torqued.
Just my hazy remembering.
Gary- Top
Gary, I would clean the threads of all older bolts and nuts to have a better chance at getting proper torque.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Michael is correct.
Here is a chart that I found on the internet. Very similar to what I taught at the local community college over 50 years ago
When a bolt is lubricated - less torque is required to achieve bolt axial load or tension. Reduction of torques for lubricated vs. dry bolts are indicated in the table below.
ExampleNo lube 0 Graphite 50 - 55 White Grease 35 - 45 SAE 30 oil 35 - 45 SAE 40 oil 30 - 40
Dick Whittington- Top
Perry,
If you are using an aluminum block, my own recommendation would be to use head studs instead of bolts. Torque a bolt threaded into aluminum and you wear the aluminum. Hand thread a stud into the block and no wear takes place. All of the wear, if any, will happen in the top threads of the stud when you torque the nut.
This is what I've done with the aluminum blocks I run in my vintage racer.
Jim- Top
