Need to replace gear plate on 60 window regulator. Remove spring and rivet. Spring holder stud is crimped over so is correct procedure to grind off then weld stud back to plate.
C1 window regulator repair
Re: C1 window regulator repair
Ed,
Attached is a PDF of the article I wrote for the Texas Chapter Talepipe Newletter with the steps I used many moons ago to replace a '57 window regulator gear.
IIRC I got the how to tips from Joe Calcagno of the Southern California Chapter.
Gary
Attached FilesNCRS Texas Chapter
https://www.ncrstexas.org/
https://www.facebook.com/profile.php?id=61565408483631- Top
Gary,
Joe is also a member of the Northern Cal Chapter and his shop is in Soquel, which in a bit southeast of Santa Cruz, so in the northern part of the state, relatively speaking. His website is rarecorvettes.com.
Gary- Top
