This is an ongoing issues....and linked a video of the issue.
When I initially start the car I have this surge and you can see the economy stop movement on the fuel meter on the video...it continues until the engine warms up. Afterwards...when I give it gas, the engine revs up, holds, and slowly comes backs down to idle RPM's (around 950). I have gone through the choke, checked for vacuum leaks...went through the timing settings multiple times, vacuum gauge checks and still stumped...new plugs but I did switch over to electronic ignition years ago and never any issues with that.
I keep thinking its in the Fuel Meter itself.....I have rebuilt the unit twice over the past 26 years and reached out to some of the FI NCRS Master Guru's to buy rebuild kits and get my wobble pump rebuilt after letting the gas setup and gum it up. So any thoughts...and thoughts appreciated.
Larry
Larry
