C2 Spare Tire Carrier
Re: C2 Spare Tire Carrier
I have 205 70 series radial in my daughter's '67. It's mounted on a 15" black steel rim which is 5.5" wide. That "tested positive".
Had I used a '67 rally wheel with the same tire, I suspect it would also fit. That's not tested, but I plan to try that soon.https://MichiganNCRS.org
Michigan Chapter
Tom Dingman- Top
They do, but nice examples are getting harder to find...- Top
The bolt pattern is fine and its been "test" bolted up to both my 61 and 63 cars...the diameter is close to the original tire; enough so that I feel OK 'limping' to a nearby gas station with it on the rear of a posi unit... It isn't designed to be driven on very far or very fast; although I've seen morons doing it.
It also fits flat in the 61 spare cavity without the plywood cover hooved up as with full-size radials.. Its an S-10 T155/90D 16
I have an original 63 rim with a "piecrust" bias tire that was in the car for judging - way too old to count on in a jam though...
Having said all that, some claim to keep an "uninflated" full size spare in the tub with a portable air pump (or Slime Fix-A-Flat) as a last ditch solution - I have no personal knowledge of how well that works.- Top
Tom England - The advice I read from Frank is that the S-10 spare fits his 61 & 63. If you are planning on installing this on a 1967, would the disc brake caliper pose different offset and fit issues? Might be a good idea to see if someone has experience installing one on a 65 and up. Just a thought before you buy one.
Brad Hillhouse- Top
Brad,
Good point, I’m not sure if the tire tub changed from 63-67 or not. Normally only the wheel offset is affected by the calipers and the overall diameter of the mounted tire would be the same. Hopefully someone will chime in with a definitive answer.
To- Top
Here is a tire size chart to determine a tire to fit the tub. Looks like a 205/70R/15 would work. 26 inch diameter
https://tiresize.com/chart/- Top
I picked up an original S-10 spare from the local wrecking yard. The tire size was the typical T155/90D x 16. It would not clear the calipers on the rear of my 65. The front was okay. I don't know if there was a change in the rim design in different years. I'd much rather make a simple cell phone call and have insurance pay to have my car flat bedded home instead of changing tires on the side of the road with cars whizzing by.Tom England - The advice I read from Frank is that the S-10 spare fits his 61 & 63. If you are planning on installing this on a 1967, would the disc brake caliper pose different offset and fit issues? Might be a good idea to see if someone has experience installing one on a 65 and up. Just a thought before you buy one.
Brad Hillhouse- Top
