'63 interior door lock (need advice) - NCRS Discussion Boards
  • Daniel J.
    • July 29, 2007
    • 158
    The interior door lock does not work on drivers side. All other locking/unlocking functions work as designed.
    I know there are a few rods in there, but does anyone have a good method of trouble shooting the problem and a good fix (before I put the door panel back on).
    Thanks in advance, Dan
  • Alan D.
    • January 1, 2005
    • 2027
    Re: '63 interior door lock (need advice)
    Look at Sec 1 sheet E7.00 of the AIM
    My first guess (& that's what it is) would be the location of #3 Lock Asm - the rod direction seems like it can be reversed
      • 6940
      Dan you maybe able to roll the window down and peak inside door with a light and see if something is unhooked.
      • Frank D.
        • December 27, 2007
        • 2703
        This is for a later midyear but comparing the AIM pictures the mechanism hasn't changed from 63...the pictures might show you where the problem area is...
        • Daniel J.
          • July 29, 2007
          • 158
          thanks all.
