I had my 63 327/340 engine completely restored with new OEM cam, lifters, valves, pistons... I noticed that the temp gauge is now showing +/- 200 degrees on the open road when previously it showed 180. The thermostat has been tested, the sending unit and the gauge have been calibrated. The temperature at the head, (infra red gun) matches the gauge. I have read the Performance manual, shop manual & technical manual and the answer is not clear.
Three questions:
- Is it normal for an authentic 327/340 to run at 200-210 degrees on the open road in 90 degree ambient temperatures at low elevations, central US.
-Given the high performance nature of the engine, should a 327/340 be able to sit at idle for an extended period, 10-20-30 minutes in a parade.., without overheating?
-Can restored motors run hotter?
Much appreciated.
Bob
Three questions:
Much appreciated.
Bob
