We have tried 3 different fuel pumps on the car (original, used original, new replacement) with the same results. We have checked that the return line to the tank is open, and leaving the gas cap off has no effect. Same result with all 3 pumps.
We have tried 3 Quadrajets on this car (original, new Edelbrock 1901 Q-jet replacement, restored carb from another Corvette) with the same results. In the course of this I meticulously have gone over the original carb several times, the last time installing a new rebuild kit from Cliff Ruggles. No change. I did the same with the other restored carb; no change. I have been playing with Q-jets for 25+ years so none of these were my first time looking inside one.
We discovered yesterday that if you prop open the throttle so that all 4 barrels are open, then you do NOT get gas in the intake. You can spin the starter and engine as much as you want with the throttle open and get no fuel accumulation in the intake. If you then close the throttle, the fuel accumulates immediately.
Any suggestions or discussion would be appreciated at this point.
