67 generator - NCRS Discussion Boards
67 generator
  • Dennis W.
    • June 30, 1991
    • 45
    67 generator
    Is it possible for a 67 vette built in september of 66 to have a alternator built in 65? Thanks Dennis (19495)
  • Tom D.
    • September 30, 1981
    • 2126
    Re: 67 generator
    Anything is possible, but NCRS says "six months" unless you have proof documents.
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
    • Dennis W.
      • June 30, 1991
      • 45
      Re: 67 generator
      Thank you for your help.
      • Wally A.
        • May 31, 1979
        • 170
        Re: 67 generator
        i do have a correct 37 amp. for your application, if you are looking for one. good shape. Wally
        • Dennis W.
          • June 30, 1991
          • 45
          Re: 67 generator
          What is the date, has it been rebuilt and how much? Would by any chance have a steering wheel hub for the 67 or a holley carb, not service type? Thanks Dennis
          • Wally A.
            • May 31, 1979
            • 170
            Re: 67 generator
            Dennis, will check numbers Sunday. out of town till then, Wally
            • John D.
              • June 30, 1991
              • 874
              Re: 67 generator
              FWIW. My early 67 has an alternator from July 66.
              • Dennis W.
                • June 30, 1991
                • 45
                Re: 67 generator
                Thanks I appreciate your taking your time, Dennis
                • David H.
                  • June 30, 2001
                  • 1485
                  Re: 67 generator
                  Dennis
                  What engine (Base, L79, L36, L68, L71, etc) does you car have? Does your car have C60 - Air Conditioning? Does your car have Transistor Ignition? Does your car have both A/C and TI?
                  What part number is on your alternator? Amps?
                  There are 15 Originality points associated with Alternator. If only "Date" is an issue, then that would be a 3 point deduction (out of 4500 total points).
                  Dave
                  Judging Chairman Mid-Way USA (Kansas) Chapter
                  • Dennis W.
                    • June 30, 1991
                    • 45
                    Re: 67 generator
                    The 67 is an L79 car with 327/350 engine. No a/c or TI. Thanks, Dennis
                    • David H.
                      • June 30, 2001
                      • 1485
                      Re: 67 generator
                      Dennis
                      Alternator part number in that case is 1100693, 37 Amps.
                      Dave
                      • Wally A.
                        • May 31, 1979
                        • 170
                        Re: 67 generator
                        Dennis, back home, have one dated 6E12 1100693-37 amp ready to use. been rebuilt, date was not correct for my car
                        the reason i changed it out.. if interested i can send a pic. Wally
                        • Dennis W.
                          • June 30, 1991
                          • 45
                          Re: 67 generator
                          Yes,I would appreciate seeing a picture. Dennis
                          • Wally A.
                            • May 31, 1979
                            • 170
                            Re: 67 generator
                            IMG_0056.jpg picture installed, could forward more pic's
                            • Wally A.
                              • May 31, 1979
                              • 170
                              Re: 67 generator
                              IMG_0059.jpg another pic of back side, hope this helps
