What year corvettes did point shield covers come from the factory? My research finds 1970-74, is that correct.
GM #1846216 Point Shield Covers
Tags: None
- Top
Re: GM #1846216 Point Shield Covers
Michael------
Yes, 1970-74 is correct with it starting later in 1970 as Terry has noted. However, and unknown to a lot of folks, the shields were also added to SERVICE distributors for earlier applications beginning in about 1971.In Appreciation of John Hinckley- Top
Joe, thank you. I think we were all waiting for your response. Can I assume the shields were also used on Camaros, Chevelles, and Novas.- Top
Michael-----
Yes, the shield was also used on other Chevrolet models as well as most other GM car and truck lines in the 1970-74 period.In Appreciation of John Hinckley- Top
That's interesting. I've worked on a lot of '70-'74 GM cars but never saw on with a shield.
What is its purpose?Mark Edmondson
Dallas, Texas
Texas Chapter
1993 Coupe, 40th Anniversary, 6-speed, PEG 1, FX3, CD, Bronze Top- Top
Mark-------
Radio interference suppression. One reason why a lot of GM vehicles with these shields have been "shorn" of them over the years: GM instructed that when the Uniset point sets (assembly of points + condenser) were used, the shield was to be removed. Apparently, the Uniset points have some sort of inherent RF suppression which obviates the need for the shields. In fact, I'm not sure that the shields can even be installed after Unisets are installed.In Appreciation of John Hinckley- Top
The configuration of the Uniset point sets precludes installation of the RFI shield. The problem is two objects can not occupy the same space.Mark-------
Radio interference suppression. One reason why a lot of GM vehicles with these shields have been "shorn" of them over the years: GM instructed that when the Uniset point sets (assembly of points + condenser) were used, the shield was to be removed. Apparently, the Uniset points have some sort of inherent RF suppression which obviates the need for the shields. In fact, I'm not sure that the shields can even be installed after Unisets are installed.Terry- Top
Peter, the shield I have in the picture also has the label on the inside.- Top
- Top
AC673DC4-B883-4455-BF08-1A1FC2DCDF9C.jpgMy ‘70 Z28 distributor with the points shield.DAN- Top
