I am putting my 1970 LT1 back together after an engine re-build. In the Assembly Manual, it shows the fan belt routing on page K185 and it shows the belt for the A.I.R Pump going around the pulley on the water pump and the alternator belt going around the crank pulley and also the water pump pulley. It seems to show another belt wrapping around the crank pulley and the water pump pulley. I don't believe my car, when I took it apart, had this last belt that I mentioned on it at all.
If that routing I mentioned above is correct, how would you tighten that last belt, if it actually did go around the crank pulley and the water pump pulley? There would be no adjustment for it. Do I have this correct, would there be 3 belts on my car?
Jim
Jim
