I'm guessing that the springs are what carry the weight and establish ride height. So I'm also guessing that shocks are designed to control the moving suspension weight so there is a difference in the valving, diameter and other. So if I'm at all in the ball park what would you expect if you put the front shocks off a 63 C-10 pickup on the rear of a midyear corvette. I'd guess the C-10 A arms and hubs and wheels/tires would weight more that the corvette rear but not a lot so the shock would be stiffer....does this seem right? What would you expect in the corvette ride?
I can get the shocks but wonder if it would be a waste of money. They would be period correct oil filled shocks.
