What is going here....... - NCRS Discussion Boards
  • Dick C.
    Past NCRS President
    • November 1, 1995
    • 450
    Anyone have an opinion of what this picture tells ya (black marks)
    Dick Capello
    New England Chapter/Mid Atlantic Chapter
    Past NCRS President
    Past Region 1 Director
  • John F.
    • March 23, 2008
    • 2395
    Re: What is going here.......
    Not a properly prepared surface to paint.
    • Frank D.
      • December 27, 2007
      • 2703
      If some light, gentle compounding doesn't lighten then up then, unfortunately, I suspect its paint prep issue...or a contaminant that's leeched into the paint.
      Where are these spots ? On the hood surround near the master cylinder ?
      I had dark spots on my cars the size of pinheads showing up, tar like, and hard to remove...chased them for years.
      Then I did some research recently and found out about "artillery fungus" - and, yes, its a real thing...
      • Robert P.
        • October 19, 2019
        • 300
        is there a cure for that fungus
        regards Bob
        • Mike M.
          • May 31, 1974
          • 8365
          perhaps Janet , a known sufferer of toe nail fungi, was tap dancing on the paint. (I'm really gonna hear it from Janet) . Saint Michael.
          • Frank D.
            • December 27, 2007
            • 2703
            Not to hijack, but the fungus is a real problem in the mid-to-South Atlantic area (pictured on car). Permanent cure: remove mulch, replace with stone "hardscape", temporary: cover old mulch with new mulch regularly..
            Back on topic; the OP's damage looks lighter in nature and irregularly shaped; my first thought was DOT 3 brake fluid or the like...its certainly not solvent pop and not blister-like..
            • Thomas N.
              • July 31, 2002
              • 387
              Dick:
              I've seen issues like that when someone used a bra on a lacquer based paint job. The lacquer was still soft and some of the backing from the bra leached into the paint. I don't know where this is located, but I've seen it happen on a freshly painted Red Mustang in lacquer. i'm not saying that is your situation, but just letting you know what I've seen in the past.
              I've also learned to never put relatively fresh lacquer t-tops into their bags.
              NCRS New England Chapter Chairman 2022, 2024
              N E Regional Chairman 2024
              1967 Corvette Convertible Under Restoration
              1996 Corvette Coupe NCRS Chapter Top Flight 99.5, NCRS National Top Flight 100.0
              • James G.
                • August 22, 2018
                • 783
                [ATTACH=CONFIG]101020[/ATTACH]
                Is that Base clear? or single stage? lacquer or enamel?
                If that is on a horizontal surface, hood, deck, rear surround, it looks like leaves or plant/organic material sat on a car and leached out whatever were in it... I have seen staining like that on red lacquer more than I can count.
                If it is on a base clear the same thing can happen if previous lacquer issues were not taken care of prior to the base clear or a enamel job.
                If it is base clear, and under the clear it probably will not come out... if you have single stage chances are something can be done to lessen it's visibility.
                James A Groome
                1971 LT1 11130 - https://photos.app.goo.gl/zSoFz24JMPXw5Ffi9 - the black LT1
                1971 LT1 21783 - 3 STAR Preservation.- https://photos.app.goo.gl/wMRDJgmyDyAwc9Nh8 - Brandshatch Green LT1
                My first gen Camaro research http://www.camaros.org/forum/index.p...owposts;u=4337
                Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453
                  • 6940
                  Dick, all you need to do is clean the spots on your glasses. All I see is a yellow car.
                  • Dick C.
                    Past NCRS President
                    • November 1, 1995
                    • 450
                    Beware................Janet said you should hire a beer taster
                    Dick Capello
                    Past NCRS President
                    • Stewart L.
                      • March 1, 1980
                      • 351
                      I think you should take it back to the guy you bought it from for a warranty repaint.
                      It that possibly lacquer? it appears to have absorbed some contaminants. If polishing and or baking in the sun for a while doesn't get rid of them them its strip and repaint.
