Low RPM Misfire Cured - NCRS Discussion Boards
  • George J.
    • March 1, 1999
    • 774
    All,
    I have had a slight miss at low rpm, while cruising, for a while. I finally got around to ordering and installing a new breaker plate ground wire as mentioned in some of the older threads. I recommend anyone who has a similar issue to do this. The old wire, was very stiff, while the new is very flexible. It did come with two ends that had tabs to be screwed down. I had to take one off and use the bare wire at one terminal.
    George
