C1 Powerglide Spacer to Block Bolt Specs - NCRS Discussion Boards
  • Garry M.
    • June 30, 1997
    • 49
    Hi,
    Looking for the 3/8-16 Hex Flange (washer) Head bolt details (length, grade, head markings, serrated) for the five bolts that mount the powerglide spacer plate to the block? Since the engine came pre-assembled, no part numbers that I can find to attempt a search.
    Best I can figure is they are 1" or 1-1/8" long and the head is serrated to negate the need for a lock washer. I assume they are all the same size... I'm not sure if these could be same bolts as those used on the aluminum bell housing for 1960.
    Cheers
    Garry
  • Stephen C.
    • May 31, 1988
    • 65
    Re: C1 Powerglide Spacer to Block Bolt Specs
    Gary try Fatsco Transmissions in NJ , they may be able to help. 1-800 524 0485.
    steve
