71 454 automatic No A/C car...Wire harness extra plugs question C3 guru's - NCRS Discussion Boards
  • Grant W.
    • December 1, 1987
    • 407
    Re: 71 454 automatic No A/C car...Wire harness extra plugs question C3 guru's
    Hi Gary
    I did go to that page.
    So hard to tell when you don't know what to look for.
    That could be the needle that I was looking for. As you said it goes through the firewall.
    I will check it out this weekend when I have a free moment. A little tired from work tonight
    I will let you know if that is the varment that has been keeping me up at nights.
    Thanks, grant
    • James G.
      • August 22, 2018
      • 783
      Grant,
      Here of a 71 19k mile LS5 automatic - June built car - showing the connection on the carb solenoid and the ground location on the reversing relay.
      After re-reading I noticed you have PW... my car does as well... the circuit breaker mounts where you had the reversing relay, over by the Tune -up sticker.
      James A Groome
      1971 LT1 11130 - https://photos.app.goo.gl/zSoFz24JMPXw5Ffi9 - the black LT1
      1971 LT1 21783 - 3 STAR Preservation.- https://photos.app.goo.gl/wMRDJgmyDyAwc9Nh8 - Brandshatch Green LT1
      My first gen Camaro research http://www.camaros.org/forum/index.p...owposts;u=4337
      Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453
      • Grant W.
        • December 1, 1987
        • 407
        #18
        Hi James
        Yes I have that same two holes in the side for your--- circuit breaker mounts to. I have to find that relay(put it somewhere) and the wires that hook up to it.
        I may have to look at my old wire harness and check it out.
        But in the first picture Gary Craig said the two wires and dual clip could be for ---Is that wire (first picture) the automatic trans kickdown switch wire?
        I still haven't a chance to take a look.
        But all other relays/reverse relay and ground wire and correct wiper pod have been installed. I have to install the 5 port wiper pump.
        So it is what your third picture I have to figure out and see where the wires come from and the kick down wire if it goes through the fire wall.
        I appreciate your help.
        Grant
        • James G.
          • August 22, 2018
          • 783
          #19
          Grant,
          Here is a link to a group of photos of the 19k mile car that you might find helpful some are when I helped him pull the radiator to have the core replaced, great ones of the original rad hoses... toying with a macro lens on some of these groups.
          James A Groome
