Can you tell visually the difference between a 58 clutch fork and a 70 clutch fork while in the cars? After finishing up my 70 I can hardly push the clutch in. Original clutch linkage except rod from cross shaft to fork. Used a standard clutch, not heavy duty in the 70, Delco brand. It is an LS5 with M20. Thought I might have put the cross shaft in backwards but it looks correct by the assembly manual and judging guide. I used a clutch fork that came with the car in boxes of parts with the 70, used original. Am sure hoping I can figure this out without pulling the transmission back out. Any thoughts appreciated.
1970 clutch fork
Re: 1970 clutch fork
Howard------
Unfortunately, it's somewhat difficult to tell them apart. However, note that the 58 fork has a much thinner center section than the 1966-81 fork. Your car was originally equipped with fork GM #3887177. The 1958 fork was GM #3739043.
They are pictured below:
3739043
GM #3887177
DSCN1114.jpgDSCN1115.jpgDSCN1116.jpgIn Appreciation of John Hinckley- Top
See this post with reference photos of the clevis rod pin end of both configurations.
https://www.forums.ncrs.org/showthre...345#post621345
The C1 fork has a nearly 90* angle to the overall long part of the arm. Another photo of the C1 here...
https://www.forums.ncrs.org/showthre...369#post621369
The C2 fork has a much greater clevis pin end angle with respect to the arm.
Ahhhh, also just found this thread with excellent photo comparisons.
https://www.forums.ncrs.org/showthre...ht=clutch+fork
Rich- Top
Rich
Thanks for these photo references. With these and Joe's pics it should be easy to determine if I used the right fork in my 70, especially with the boot off. If it is right I will have to figure out what else is causing the linkage to feel like it is binding.
Howard- Top
