1972 headlamp assembly removal - NCRS Discussion Boards
  • Larry M.
    • December 1, 1986
    • 541
    On a 1972, if the front bumper and grilles are removed, can the complete headlamp assemblies be removed through that front opening?
    • 6940
    • Larry M.
      • December 1, 1986
      • 541
      Re: 1972 headlamp assembly removal
      Ed,
      Thank you. Another option would be to remove the hood and extract the assemblies from the rear; but I don't like R&R'ing the hood because I've had a couple of very frustrating experiences getting the latches to work properly afterward.
      Larry
      • James G.
        • August 22, 2018
        • 783
        I don't think the entire assembly will come out through the grilles... I know the doors will come out, I recently removed a pair for painting on a 69, I think I tried to pull the whole assembly, all I remember is quickly getting an allen wrench .
        James A Groome
        1971 LT1 11130 - https://photos.app.goo.gl/zSoFz24JMPXw5Ffi9 - the black LT1
        1971 LT1 21783 - 3 STAR Preservation.- https://photos.app.goo.gl/wMRDJgmyDyAwc9Nh8 - Brandshatch Green LT1
        My first gen Camaro research http://www.camaros.org/forum/index.p...owposts;u=4337
        Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453
        • Larry M.
          • December 1, 1986
          • 541
          James,
          Thank you. I've been looking at the area down there, and it looks like it would be a tight fit to remove the assembly that way.
          Larry
          • John S.
            • June 15, 2015
            • 505
            1973 L82 M21 4 Speed, very original and well documented driver/survivor
            NW Chapter Member, 2016 Bend Regional Top Flight
            73/74 TIM&JG 3rd Edition Revision Team Member
            • Larry M.
              • December 1, 1986
              • 541
              John,
              Thanks for your info; good thought on the cardboard. No AC on ours, so I'll have a little bit more maneuvering room. I won't know how it'll work until I try.
              Larry
