A friend recently purchased a 67 427/390 that has been converted to 435 tripower and I am clueless about these despite a couple of hours reading searches here.
1. His clutch linkage is adjusted to the very last set of threads on the clutch push rod and he still grinds a bit in gear. While he does have extensive maintenance and repair records going back over a dozen years there isn't any mention of clutch replacement. Years ago when i rebuilt my 66 Joe L (I think) suggested Luk clutch and throwout bearings for my L79. Are they still a "go to" clutch? The GM Heritage Center download says he should have a 14" flywheel and 11" clutch. Can a heavily worn clutch cause that much clutch rod positioning? I also very vaguely remember that there was a tall and short throwout bearing and one was appropriate for the Corvette but the other one was not. I cannot remember which is which. Any help on the clutch and throwout bearing?
2. The car runs really well with the tripower but the center carb (3660?) is leaking quite a bit at the fuel fill line going in to the carb. It looks like the entire fuel line assembly for the three carbs needs to be loosened in order to pull the large nut off and replace the gasket. Is that correct?
I am still searching and gathering information on this and I do appreciate the help.
Gary
Gary
