Cracked Harmonic Balancer
Re: Cracked Harmonic Balancer
The fit must be out of tolerance. If you are lucky the crank snout isn't worn under size and the replacement will go on with a press fit.
IF you have access to a 1-2" micrometer you can measure it in several places around the circumference to check for wear.
Excuse me if i am stating the obvious.
Rick- Top
Thanks Rick. The new balancer was pressed on with the tool required. We shall see but at this point it is what it is, as they say.1966 L79 Convertible. Milano Maroon
1963 Corvair Monza Convertible- Top
