I've just completed to wonderful task of removing my oil pan ('65 250 hp 327) in order to remove the broken piece of the dipstick tube stuck in the block. While I wait for the new part, seals and gaskets to arrive I thought I'd ask what IS the proper way to install these tubes?? Obviously when I reassembled the engine 11 years ago, I not only made the mistake of reusing the original tube but I recall installing it with a flat screwdriver and tapping it in around the flange.
reading the technical archives, Joe L. and others indicate this will eventually cause a failure and this is exactly what happened.
