In the early 1980's I rebuilt the steering column with new bearings as well as a GM shaft, # 5690810, on my 1966. Attached are 3 photos of the 37 1/32" long original shaft. The 0.75" diameter shaft is slightly scored at a point 15" down from the top end (scored diameter measures 0.73", see photo #2) as well as at a point 6 1/2" from the bottom end (scored diameter measures 0.69", see photo #3).
Is this shaft salvageable or is it 4.5 lbs. of steel for the recycling bin?
Dave
Dave
