Timken bearings for �66 front hub; preferred vendor? - NCRS Discussion Boards
  • Gary B.
    • February 1, 1997
    • 6979
    I have a set of GM/Delco NOS hubs/rotors that already have the bearing cups installed. Should I remove those NOS cups and install the Timken cups that come as part of the Timken cup/cone set? Or can I leave the NOS GM/Delco cups in place?
    Gary
  • David H.
    • June 30, 2001
    • 1485
    Originally posted by Gary Beaupre (28818)
    ...Should I remove those NOS cups and install the Timken cups that come as part of the Timken cup/cone set? ...
    Gary
    Standard practice is to replace both bearing and race as a set.
    Dave
    • Gary B.
      • February 1, 1997
      • 6979
        Originally posted by David Houlihan (36425)
        Gary
        Dave
        Dave------
        That is the standard practice IF one is replacing wheel bearings. That's because the bearings and cups will be equally worn and "worn in" together. However, if using brand new rotor/hubs with pre-installed cups, there is no problem with using the pre-existing NEW cups with NEW bearings.
        • Gary B.
          • February 1, 1997
          • 6979
