I've been working on a '64 L75 (300HP) engine and after a long hiatus started assembly. The crank and pistons are in the block, and tonight I started measuring deck clearance to help inform head gasket choice.
I measured deck clearance using a deck bridge and dial indicator. I took measurements at 12 o'clock, center, and 6 o'clock of each piston and then averaged. Results (also included head chamber volume in ccs):
My pistons are Keith Black KB 156 (dish = 7 ccs) and are 40 over. These values produced compression ratios as follows assuming a Fel-Pro steel shim head gasket
Assuming a Fel-Pro perma torque gasket, I get this:
Will measure the other side of the engine after dinner, but wanted to record results. Duke Williams has been patient with me for a decade -- this engine is getting a McCagh Special camshaft and I'm eager to get it installed and see what it will do.
| Bore | 12 o'clock | center | 6 o'clock | average | head volume |
| 1 | 18 | 19 | 22 | 20 | 64.8 |
| 3 | 14 | 16 | 20 | 17 | 63.8 |
| 5 | 15 | 17 | 21 | 18 | 63.8 |
| 7 | 17 | 19 | 23 | 20 | 64.6 |
| Bore | CR |
| 1 | 9.6 |
| 3 | 9.75 |
| 5 | 9.73 |
| 7 | 9.6 |
| Bore | CR |
| 1 | 9.08 |
| 3 | 9.23 |
| 5 | 9.21 |
| 7 | 9.10 |
