327/300 Exhaust Manifold Washers/Bell Housing Bolts - NCRS Discussion Boards
  • Grant M.
    • August 31, 1995
    • 448
    Hi,
    Can anyone advise what washer/washers should be under the exhaust manifold bolts on a 327/300 (1965)? I know there are flat, thick washers and perhaps lock washers as well, but I'm not sure whether they're on all bolts or only certain ones. Also, what are the proper bolts to fasten the bell housing to the block? They have integral washers, but I've seen recessed head and flat head. Which is correct?
    Grant
  • Richard G.
    • July 31, 1984
    • 1715
    Re: 327/300 Exhaust Manifold Washers/Bell Housing Bolts
    Grant;
    I thought I recorded the measurement. I will have to continue to look.
    I only have a picture of the ones I made.
    I will look as I believe I have extras. You are welcome to them if you don't mind stainless steel.
    The originals are steel of course.
    Rick
      • 43193
      Originally posted by Grant MacDonald (26607)
      Hi,
      Grant
      Grant------
      The thick washers were under all manifold bolts except the 2 long bolts on each side at the center position. They are installed against the manifold regardless of whether french locks or RF shield brackets are also installed.
      On the bellhousing bolts, I've never seen anything but non-trimmed ("indented"), flanged head bolts used. However, it's very possible that trimmed ("non-indented") head were also used.
      • Grant M.
        • August 31, 1995
        • 448
        Joe,
        Thanks, and just to clarify: do any/all of the manifold bolts have lock washers? And, in your comment about the thick washers being "installed against the manifold regardless of whether french locks or RF shield brackets are also installed", do I take that to mean: manifold surface/flat washer/ then, french lock and/or RF shield bracket, meaning that the lock or shield bracket would be sitting on the flat washer? And if lock washers are also used, where do they fit in the order?
        Thanks again for your patience and help!
        Grant
        • Grant M.
          • August 31, 1995
          • 448
          Rick,
          Thanks very much. I have stainless washers (driver car), but they only came in a pack of eight, so I wasn't sure whether I needed more or which bolts they went on. Thanks too, for your offer of spares...
          Grant
            • 43193
            Joe,
            Grant
            Grant------
            No lock washers were used for any manifold bolt. For the end runner positions, french locks serve the locking purpose. For the center runner position, no locking features were used.
            Manifold surface, then flat washer, then whatever else.
              • 43193
              Rick,
              Grant
              Grant------
              A pack of eight is exactly the number needed-----there are 4 end runner positions requiring 2 washers for each position (one on each end runner bolt). So, eight total is what's needed.
              • Grant M.
                • August 31, 1995
                • 448
                Thanks very much Joe!
                Grant
                • Leif A.
                  • August 31, 1997
                  • 3607
                  Grant,
                  A picture is worth...
                  Leif
                  • Grant M.
                    • August 31, 1995
                    • 448
                    That's excellent, Leif. Many thanks!
                    Grant
