found this on ebay and list a whole list of GM cars applications but I want to know if it will fit a 65 Buick or Olds tilt column switch and if this will fix a switch that does not cancel?
GM 5957066 Signal Switch Contact Set
Re: GM 5957066 Signal Switch Contact Set
Can you post a Link? Never mind.......
I think a non cancelling issue is likely due to a broken plastic piece inside the switch or a bad cancelling cam on that Buick or Olds.
This Site says '65 but not for tilt wheel.... so the answer to that one is no.
This new old stock turn signal switch spring package ( contact unit ) was manufactured by General Motors for use on the following models: Buick 1964 – 1965 Special, Skylark less tilt wheel. Chevrolet 1964 – 1967 All, Corvette. Oldsmobile 1964 Cutlass except tilt wheel -Guide, Oldsmobile 1965 – 1966 All except tilt wheel. NOTE: Images […]
s-l1600.jpg- Top
