Coil spring tape/tag location - NCRS Discussion Boards
  • Gary B.
    • February 1, 1997
    • 6979
    • 11608
    Re: Coil spring tape/tag location
    Often you can move them around the spring, ie they're not stuck in place after 50 years.
    Most commonly I see them toward the centerline of the car.
    • Gary B.
      • February 1, 1997
      • 6979
      • Ron G.
        • December 1, 1984
        • 865
        I have usually seen them at the 3rd or 4th coil from the bottom. Be sure to face the tail inward.
        "SOLID LIFTERS MATTER"
        • Gary B.
          • February 1, 1997
          • 6979
          Ron,
          Gary advice. What position around the coil have you seen on originals?
          Gary
          • Ron G.
            • December 1, 1984
            • 865
            • Gary B.
              • February 1, 1997
              • 6979
              • Loren L.
                • April 30, 1976
                • 4104
                I would believe that Ron G. is absolutely correct - this is a tag placed by a human so that another human can identify it while it is not installed on the car. It could be anywhere.
                • Gary B.
                  • February 1, 1997
                  • 6979
                    • 11608
                    Originally posted by Gary Beaupre (28818)
                    Having said that, I bet there are judges who have opinions about a “typical” location. Which is why I’m asking before I put on the tape. It’s done in the spirit of NCRS, Never Can Research Stop.
                    Gary
                    Nah, I've seen them all over as well. One that recently was here had the tag so high I wasn't sure it was on the car, but I found it.
                    Just stick it on like you're paid base wages, and move on.
                    • Gary B.
                      • February 1, 1997
                      • 6979
                      OK. Enough research on this project.
                      Thanks all,
                      Gary
                      • Ron G.
                        • December 1, 1984
                        • 865
                        I was referring to the 3:00 position that faces inward toward the center of the chassis and the 9:00 position facing the spindle.
                        • Gary B.
                          • February 1, 1997
                          • 6979
                          • Ron G.
                            • December 1, 1984
                            • 865
                            No, it would be towards the front.
                            • Gary B.
                              • February 1, 1997
                              • 6979
