So, I pulled the water pump to fix a leak at the upper driver side bolt and correct some configuration issues at the same time. I repainted the front motor mount brace and the water pump. Used Hylomar Blue non-setting gasket sealant on the upper and lower radiator hose and heater hose and put it all back together. After 24 hours, I refilled the radiator and started her up. Ran fine up to temperature without any leaks so I thought I was golden until I shut her off and the coolant pressure built up. All of a sudden, there's a massive coolant explosion rivaling Old Faithful! Found that the lower radiator hose slipped off the water pump.
I've gone through all the threads relating to this and see that I probably should not have painted the neck of the pump as the paint and slippery nature of the coolant can cause the hose to come off. (I had no previous problem with this happening). I plan on removing the paint from the neck of the pump and reassembling it but before I do so, I wonder if any of you have any further suggestions to keep this from happening a second time?
