I need to know the size and type of this screw. LIC lists one type and Paragon lists another. Thanks in advance.
'67 Horn Contact Screw #159612
Re: '67 Horn Contact Screw #159612
David,
Thank you very much. Paragon's are clutch head (don't know where they got that idea from). LIC are a pan head. I'll check Home Depot and Lowe's first.Leif
Top Flight 2017 Lone Star Regional- Top
Leif,
I found the following #8-32 screws in my collection:
On left: 0.31" dia. Phillips head #8-32 X 1/2"
Center: 0.31" dia. Phillips Head #8-32 X 1/2" with "star" lock washer
On Right: 0.37" dia. Phillips Head #8-32 X 5/8".......I would say that these would be a good substitute for the GM 159612 #8-32 X 5/8" Pan Head Cross Recess Machine screws. I would have to compare them to the 159612 screws on my 1966 Corvette.
Dave
- Top
David L and David B,
Thank you both for the additional information. As an aside, the Paragon clutch head screws also had the star lock washer included...strange.Leif
Just a follow-up. Ended up buying a box of 30 screws at Home Depot for $6. If anyone ever needs any, I have a lifetime supply.Attached FilesLeif
They are #8-32 X 1/2". Couldn't find #8-32 X 5/8" anywhere. These provide plenty of "bite". Mismatched screws that were in there were only 3/8" and were holding.Leif
