For a ‘66, I’m trying to understand what was painted and what wasn’t, for the steering linkage, i.e., relay rod, tie rod sleeves, tie rod ends, tie rod end clamps, pitman arm, idler arm, and associated hardware. The C2 Judging Guides suggest that the answer might be different for 63-64, than for 65-67, and perhaps different during the C3 era. I’m specifically interested in ‘66. The ‘66 JG says that entire steering linkage was painted as an assembly. The DB archives indicate that the assembly was painted while being held by the large hole in the pitman arm and the upper hole in the idler arm, but certain components were not painted. In the attached exploded view of the steering linkage I’ve circled in blue the items that I believe should be free of paint. These include, five zerks, the tapered stud, threads, nuts, and cotter pins for the two outer tie rod ends. The upper, zinc-plated half of the idler arm. That leaves every other item in the exploded view receiving paint coverage, including nuts, cotter pins, relay rod rubber grease cover and retaining cage, bolts and nuts.(Except, of course, there was no paint on the internal springs, ball and socket components inside the end of the relay rod.) Have I got this right?
Gary
Gary
