6.2 LS Oil Pressure - NCRS Discussion Boards
6.2 LS Oil Pressure
  • Jimmy G.
    • November 1, 1979
    • 975
    6.2 LS Oil Pressure
    What are you guys seeing for oil pressure readings on 2018 or so 6.2 LS engines?? Mine seems low but I have no experience with those engines. Not sure I like 0 - whatever weight oil either.
  • Richard G.
    • July 31, 1984
    • 1715
    Re: 6.2 LS Oil Pressure
    Lots of high mileage vehicles have an issue with the "O" ring at the suction tube for the oil pump hardening and causing a leak.
    Requires dropping the pan to access.
    • Michael H.
      • December 1, 1987
      • 724
      How low at idle ? What's the pressure at 60 mph ?
      Mike
      • Jimmy G.
        • November 1, 1979
        • 975
        Idle 20 - 25 60 MPH 45 - 50
        • Michael H.
          • December 1, 1987
          • 724
          Idle pressure seems a little low, is that when it's warmed up ? Mine shows at idle when cold about 35, once it's warm about 25-30. I notice my pressure is higher after I change my oil. GM would tell you that's OK. Your pressure at 60mph seems to be normal.
          Mike
          • Jimmy G.
            • November 1, 1979
            • 975
            Warm at 25 psi or so. I may bump up the oil to 5 - 20 weight or so
            • Edward J.
              • September 15, 2008
              • 6940
