1980 Gymkhana Rear Spring
Re: 1980 Gymkhana Rear Spring
Gary,
I measured each of the leaves individually. They all measure .235. The liners measure .020. All measurements were taken close to the center bolt,
to minimize the effects of wear. The main leaf and leaf #2 are flat at the ends. Leaves #3-7 all have the same sharp bend at the end. Leaves #8
&9 are also turned up, but at a lesser angle. See the attached photo.
Mark
Mark100_0247.jpg- Top
Mark,
Thanks for the measurements. If you add up 0.235” x 9 and 0.02” x 8, you get 2.275”. That must be pretty close to the assembled thickness. Maybe Dave’s measurement of 2.545” includes some rust/corrosion.
It’s interesting that there are two shapes of the turned up ends. I hadn’t heard of that before.
Gary
Gary----
Dave's measurement includes the liners.In Appreciation of John Hinckley- Top
Joe,
My calculated thickness also includes 8 liners. I think the difference between a real measurement of the assembled thickness and a calculated measurement is caused by stacked things being thicker in total than the sum of the individual parts. You can really get things to have zero gaps between them. Plus, the paint thickness isn’t taken into account with the leaf thickness given by the Spring Research Institute.
Gary- Top
Mark,
I was fortunate enough today to be able to look at a copy of the GM engineering drawing for GM spring 14021604, dated Mar 14, 1979. It contains some interesting information. First of all, it confirms that all leaves are 0.228” thick +/- .005”. Also, it gives the assembled thickness of 2.169”, which is consistent with 9 leaves of 0.228” and 8 liners of 0.018” thick. But note that the 2.169” thickness is a design spec. It could be thicker than that if all leaves are 0.005” thicker than the 0.228” nominal spec, and because of the paint thickness.
Finally, the GM drawing shows the use of two “clips” or bands that surrounded leaves 1 thru 5. The bands are located 13.91” from the center bolt to the center of the band (clip). The attached shows a cross section of the spring/clip.
Gary
249F52BB-7876-4CA6-9877-1C218D2FCFFD.jpg- Top
Mark,
According to the GM engineering drawing for GM 14021504, leaves 1 and 2 do not have upturned ends. Only leaves 3-9 are upturned. And those 7 leaves should have upturns like the one shown in the right in your photo.
Gary- Top
- Top
