Two Holes In 1965 Coupe Frame for Each Of Three Radio Ground Straps - NCRS Discussion Boards
  • Tom D.
    • September 30, 1981
    • 2126
    Another member suggested I might ask: For U69 Radio Corvettes, is it common to see an extra un-threaded hole near the threaded hole used for "to the frame" grounding straps? I found this on the crossmember for the exhaust clamp ground straps (on both sides) as well as for the frame location for the power antenna ground strap; 1965 Corvette made in March.
    p. s.
    There's only one hole on each of the engine mounting "horns" up front.
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
  • Dick C.
    Past NCRS President
    • November 1, 1995
    • 450
    Re: Two Holes In 1965 Coupe Frame for Each Of Three Radio Ground Straps
    Power antenna ground, top hole threaded
    Late 65 - 20xxx
    Dick Capello
    New England Chapter/Mid Atlantic Chapter
    Past NCRS President
    Past Region 1 Director
    • Leif A.
      • August 31, 1997
      • 3607
      Tom,
      A picture of my '67 antenna ground strap at frame.
      Leif
      • Gary B.
        • February 1, 1997
        • 6979
        • Leif A.
          • August 31, 1997
          • 3607
          Gary,
          I guess that picture wasn't very clear (my bad). Here's a better picture...one hole only.
          Leif
          • Stephen L.
            • May 31, 1984
            • 3148
            Maybe the drill bit was the wrong size and the bolts would not tighten. Second hole (used) may be slightly smaller..........
            • Tom D.
              • 2126
              Here's my idea: The drill operator pushed too hard (or too long) the first time, and stripped the threads in the "extra hole".
              Then did it again and left a smaller hole. (I've asked Larry Galloway about this via his email.)
              Michigan Chapter
              Tom Dingman
