Early 69 Frame Stencil - NCRS Discussion Boards
  • Joseph A.
    • June 20, 2012
    • 136
    Re: Early 69 Frame Stencil
    I have a 3rd week of Jan 1969 build and they stencil I got from Quanta matched the one on my car which was 12.10.68
    • Chris H.
      • April 1, 2000
      • 837
      Mark, just be be clear, what is the date on your trim tag? That’s is your cars official build date.
        • 11608
        #18
        Originally posted by Mark Silverman (65851)
        Correct but stencil makers want to use Jan 69 dates.....and the Official production date per NCRS is 12/30/68
        Which maker?
        It makes zero sense to date a frame after a car is built. Someone on their end isn't thinking this through, no matter what.
        I would call them and explain. That's what I did for the 77 I did last year, and they made the date I wanted.
        Or choose a different vendor.
          • 11608
          #19
          Actually, its not.
          The official date is the day it rolled off the line and was invoiced. The body build date (trim tag date) is usually 1-2 days prior to that.
          • Mark S.
            • April 25, 2019
            • 94
            #20
            exactly. trim tag is 12-28. 2 days prior to when NCRS says is the production date.
              • 11608
              #21
              I would pick a date in the first 2 weeks of December; the 10th as shown above would be perfect.
              • Ron G.
                • December 1, 1984
                • 865
                #22
                Just and FYI if you are already not aware, but the paint was rolled on with a small roller and not sprayed like you see on most restorations. It was done with a very cheap white enamel paint.
                "SOLID LIFTERS MATTER"
                • Chris H.
                  • April 1, 2000
                  • 837
                  #23
                  Mark I should have clarified....when I say “official”, that is the date that will be used on the judging field.
                    • 11608
                    #24
                    because it's the closest we can come without having the actual production date on the judging field.
                    However, we usually understand that the true production date is not the same.
