GM SB oil pump spring - NCRS Discussion Boards
  • Patrick B.
    • August 31, 1985
    • 1986
    I am trying to make sure the old GM oil pump I have is the right one for a 70 LT-1. Is the GM production oil pressure spring color coded or otherwise identifiable? Also what is the correct one piece oil pan gasket for the original 1970 timing chain cover?
    • 43193
    Re: GM SB oil pump spring
    Patrick------
    The spring used for the LT-1 oil pump had a stripe of white paint and was of 21 coils. GM #3848911. The paint stripe may or may not be discernible after long use in the pump.
    There is no 1 piece oil pan gasket available from GM for pre-1980 small blocks. The Fel-Pro # is OS34509T (blue) and the Mahle # is OS32458 (black).
    • Patrick B.
      • August 31, 1985
      • 1986
      Thanks Joe
