I was calculating compression ratios of various combinations of 350 Chevy parts to get some insight on its sensitivity to deck clearance and head gaskets. I started with the baseline combination of stock 70 LT-1 parts. Duke Williams has said that Chevrolet overstates the compression ratio on some 327's that have been discussed here so I expected it to compute to about 10.5. However, I was quite surprised that my computation was actually 11.04. I wonder if the LT-1 is an outlier as far a GM reporting or that there other factors affecting my computation.
Here are the components:
Cylinder Volume of 4.00 in bore with 3.48 in stroke: 716.6 cc
Combustion Chamber of 186 head with 2.02/1.6 valves: 64.0 cc
Dome Volume of TRW L2304F: 2.4 cc
Volume of 0.025 deck clearance: 5.15 cc
Volume of 0.021 steel shim gasket: 4.6 cc
The total volume = 716.6 + 64.0 -2.4 +5.15 +4.6 = 787.95 cc
The compressed volume = 64.0 -2.4 +5.15 +4.6 = 71.35 cc
The compression ratio = 787.95/71.35 = 11.04
The original LT-1 pistons were made by TRW, and the TRW L2304F pistons have an identical dome design and only slight differences around the piston pin bore. I am confident that the TRW dome volume spec represents the LT-1 OE pistons.
The deck clearance of 0.025 in is the design clearance you see in the Chevrolet Power books, but I don't think the actual blocks are machined intentionally for a greater deck clearance. I measured the deck height on a 70 350/300 engine that had never been taken apart (with stock flat top pistons). The deck height at one end was 0.035 but the height at the other end was only 0.020. I was surprised at this variation across the length of the block. The compression ratio of the back cylinder in this case would be only about 10.8 but the compression ratio of the front cylinder would be about 11.15 with LT-1 pistons. (a whole compression point difference results from about a 8 cc change in a 350).
If GM overstated the compression ratio of the LT-1, the only place left to look is the cylinder head volume. I have not measured the volume of the 3927186 LT-1 head, but the figure of 64 cc is widely published. Does anyone have a real measurement of a nominal 64 cc Chevy head? Comments?
Reply
