Attention John Hinkley - 1964 Coupe
Re: Attention John Hinkley - 1964 Coupe
John doesn't frequent this board very often, and hasn't posted in a long time.
You might want to send him a direct email, or change your question so others can/will answer.Vice-Chairman (West), Michigan Chapter NCRS
In 2011 NCRS National Convention Technical Seminar John did the "Midyear Corvette Assembly Process"
Believe that maybe found on the Michigan Chapter web site.
You will find it under the "Hard Trim Line:" item on page 8 of that PDF.- Top
Jack and Alan,
John's presentations are provided in the STICKY at the top of the page "Database of Restoration Documents"
I've provided those links below as well...I believe Part 1 is the version Alan was referencing regarding page 8 and p/w installation steps...thx, Mark
C2 Assembly Process C2 C2 Assembly Process Part 1 - John Hinkley.pdf C2 Assembly Process C2 C2 Assembly Process Part 2 C2 Assembly Process C2 C2 Assembly Process Part 3 thx,
Mark- Top
