I hope everyone had a great Christmas and New Year.
I'm afraid this problem is doing my head in and I need all the help I can get from the much brighter minds on this forum.
I have been toiling with this alignment issue for some months now, waiting for new parts to arrive from the states which due to COVID were taking up to 6 months to arrive in Oz. After fitting the new parts (from Paragon) and then due to the misalignment reverting to refurbishing the old parts. I thought I had this problem licked but, I still have a slight misalignment of the PS pump pulley and belt as you may be able to see in the attached pics. The pump has been refurbished and tested but I think the problem lies with the adjusting bracket or the lower bracket that attaches via the bolt at the front and the nut and stud at the rear.
When fit everything (hopefully in the right order) and nipping the bolts it looks ok but the pulley alignment is off just a fraction toward the front of the car. Once I adjust the PS belt and then tighten the lower nut and bolt the pulley moves toward the engine and almost hits the new idler pulley I've fitted. The idler look pretty well aligned in the attached pics so I don't believe this is the cause.
I understand that tolerances are tight in this area of engine bay but I also would have though that fitting these brackets (and new ones I purchased) would just fit. What am I missing in all of this? Will I have to bend the adjusting bracket at the adjusting slot to ensure the PS pulley is aligned and a little further away from the idler pulley? What should the distance be on either side of the idler, between the pulley and the PS body? Do I need to use spacers to push the pump out a fraction of an inch? I don't think this would fix the misalignment, only move the pump toward the front but still be on an angle.
I'm missing something so any help would be very much appreciated if you have experienced this or a similar issue.
Cheers
Grahame
Cheers
Grahame
