62 fi distributor install problem - NCRS Discussion Boards
  • Don L.
    Infrequent User
    • May 31, 1986
    • 7
    The FI distributor fits to the FI base manifold using a thick-ring-spacer (and gaskets). This spacer has a small pin protruding from upper/lower faces. This pin seems to be designed to fit in a factory pinhole in the manifold, and a slot in the distributor body. Evidently this is to lock the distributor position for correct alignment of the FI pump drive able to the FI unit.
    Problem is my manifold lacks a factory pin hole to receive the lower spacer pin. It is the correct #2333769 manifold, and in very good unmolested condition.
    Lacking experience with FI, I'm mystified. Did the factory neglect to drill the pinhole in this manifold? Seems unlikely, but maybe not. Or is there a piece missing that makes this work? My simple solution would be to drill the needed pinhole, but exactly where? Looks like it should be about the 10 o'clock position. But I hesitate on this without confirmation from a FI guru that a pin hole should be drilled.....or that I am missing something else here for fitment.
    Don
  • Jim L.
    • September 30, 1979
    • 1805
    Re: 62 fi distributor install problem
    Maybe this will help:
    • Don L.
      Infrequent User
      • May 31, 1986
      • 7
      Short answer for long winded problem. It's easy to see where the pinhole is drilled.
      Many thanks to Jim.
      Don
      • Loren L.
        • April 30, 1976
        • 4104
        What # distributor do you have? Please note that NONE of the distributors carry over from 1961 to 1862.
        • John D.
          • December 1, 1979
          • 5507
          Very nice photo Jim Lockwood.
          Don, "62 baseplate aka intake is casting number 3788233.
          Refer to your '62-'62 technical/judging manual.Do you have an original baseplate? Put a pic of it up here please. Do this before you drill.
          I never saw an original '62 baseplate without the holedrilled. It's not drilled the hole way thru with the same size drill bit
