I see the description in the TIM&JG about how the '63 horns should be clocked, but what part of the horn is used to determine the "clocking"? Thanks.
"Clocking" horns....1963
Tags: None
- Top
Re: "Clocking" horns....1963
OK, so the outer end of the horn "bell" would then be the hand of the clock?Big Tanks In the High Mountains of New Mexico- Top
Mine, (455 and 456, correct dates) which I just had rebuilt and restored by The Horn Works, have the bells facing outboard. The TIM&JG says that is acceptable if "clocked" at 5 and 7, left and right. I am just trying to figure out what part of the horn is the hand of the clock.Big Tanks In the High Mountains of New Mexico- Top
Michael,Mine, (455 and 456, correct dates) which I just had rebuilt and restored by The Horn Works, have the bells facing outboard. The TIM&JG says that is acceptable if "clocked" at 5 and 7, left and right. I am just trying to figure out what part of the horn is the hand of the clock.
Look closely at the picture that Harry posted and you can see the 7 o'clock position of the right hand horn. Driver's side oriented at 5 o'clock. The Horn Works does nice work, don't they?Leif
Top Flight 2017 Lone Star Regional- Top
I don’t have a 63 AIM but on my 67 AIM it shows the Hi note horn on the right and the Low n the left side. In this configuration the horn “clocking” can only go one way, especially if the horns are original. Aftermarket horns... I would assume the same but who knows.
Tom
696D8254-E59C-495C-8769-A9572DAE3397.jpg- Top
That shows the difference with the '63 horns I have. The mounting bolt is above the horn on mine, these are below.Big Tanks In the High Mountains of New Mexico- Top
horns_2ed80b882fdc484ea794b4a236380d25188b2769.jpgOK, when in doubt, check the AIM. It appears whoever restored my car, mounted the horns on the wrong bolt of the core support, using the upper one instead of the lower one. If I use the lower one, then it all makes sense.......back to the garage.....Big Tanks In the High Mountains of New Mexico- Top
[ATTACH=CONFIG]103966[/ATTACH]OK, when in doubt, check the AIM. It appears whoever restored my car, mounted the horns on the wrong bolt of the core support, using the upper one instead of the lower one. If I use the lower one, then it all makes sense.......back to the garage.....
This is incorrect. The openings need to face each other so the high note and low note blend.
- Top
Maybe that is where the "clocking" comes in? Is the mounting on the lower bolt on the core support correct? I need to get a correct AIM I guess.Big Tanks In the High Mountains of New Mexico- Top
Mike, The horns mount to the raised reinforcement. There is a rob molded below the bolt hole that keeps the horn straight. As the others have indicated, as long as you have the horns mounted so they blow towards the center of the car, you will judge fine.- Top
Thanks Joe, now that I know the bolt they are supposed to mount to, they will clock out fine.Big Tanks In the High Mountains of New Mexico- Top
