I have the T.I. ignition in my 1970 LT1. Using a not so scientific method, when I pull the coil wire and crank the car, to see the spark, I don't get a very strong looking spark. Is there any way to measure the output from the T.I. ignition module? If I send it to someone to take a look at it, are ere any tests that can be run on it to thoroughly check it out?
Is it possibly the coil itself? Are there any recommendations on how to test the coil?
The car take several tries to get it started. Once it is running, is seems to run OK, but it is really difficult to get started that first time.
Does anyone have any recommendations on a restorer / re-builder of those T.I. ignition modules?
Thanks in Advance
Jim
Thanks in Advance
Jim
Just keep the old Delco in the storage console if you're ever in need for a fix, albeit I doubt the K&B would ever fail. Those are very reliable.
