69 Wheel paint - NCRS Discussion Boards
69 Wheel paint
  • Mark S.
    • April 25, 2019
    • 94
    69 Wheel paint
    I read that the 69 wheels have a unique color (nott just argent silver). Does anyone have any info on where i could order the correct color to paint my wheels?? Thanks, Mark
    • 6940
    Re: 69 Wheel paint
    Mark check with Corvette Central they use to carry the argent silver with a green hue.
    • Richard K.
      • April 1, 1988
      • 207
      Re: 69 Wheel paint
      Read between the lines of the product description before buying. I've noticed, at least, one vendor calls their product a "coating". I purchased a can recently, and, to me, it seemed different from paint. When it dried on the wheel, it's finish just didn't look "right". The color did seem good, though. The wheel that was done will go into the spare tire carrier, and won't see much of the light of day. So, I'm not stressed about it, FWIW.
      Someone once told me, many years ago, that GM's 1971 Chevrolet El Camino paint silver (name?) has the right shade of silver-green. I've never purchased any, but on a paint chip card it looked pretty close.
      • Mark S.
        • April 25, 2019
        • 94
        Re: 69 Wheel paint
        thanks will do
          • 11608
          Re: 69 Wheel paint
          One of my local friends recently tried the silver-green in an aerosol can. While slightly greener than silver, it does not match his original spare with its original paint.
          Another friend had some matched at a paint store, which worked out much better.
          • Bob W.
            • December 1, 1977
            • 799
            Re: 69 Wheel paint
            A Friend had a1971 silver El Camino and it did have a green hue. This may be a good starting point and adjusting the green tint as needed.
            • Mark S.
              • April 25, 2019
              • 94
              Re: 69 Wheel paint
              I am trying to find on OE wheel with my dates to do a color match.
              • James G.
                • August 22, 2018
                • 783
                Re: 69 Wheel paint
                I have 4 original paint OCT dated 1969 wheels, there is not a spot large enough to scan with the camera at the paint store.
                HOWEVER I matched to the color for 2 - 69's and a 71 I painted last year.
                I used GM argent silver with 4 drops of green toner per 2 OZ of paint.
                I can get you the EXACT toner numbers and weights.
                James A Groome
                1971 LT1 11130 - https://photos.app.goo.gl/zSoFz24JMPXw5Ffi9 - the black LT1
                1971 LT1 21783 - 3 STAR Preservation.- https://photos.app.goo.gl/wMRDJgmyDyAwc9Nh8 - Brandshatch Green LT1
                My first gen Camaro research http://www.camaros.org/forum/index.p...owposts;u=4337
                Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453
                • Chuck G.
                  • May 31, 1982
                  • 2029
                  Re: 69 Wheel paint
                  Check this out.
                  • Dave S.
                    • August 31, 1992
                    • 2918
                    Re: 69 Wheel paint
                    Originally posted by Chuck Gongloff (5629)
                    Maybe worth a try but my few experiences with Speedway Motors on parts for the hot rod were pretty much a failure.
                    • Chuck G.
                      • May 31, 1982
                      • 2029
                      Re: 69 Wheel paint
                      When I did a search, Amazon sells the same brand.
                      When I had my 69, IIRC, I used "OEM" brand Argent Silver-Green.
                      Maybe they still make it?
                      • Dave S.
                        • August 31, 1992
                        • 2918
                        Re: 69 Wheel paint
                          • 11608
                          Re: 69 Wheel paint
                          This is what my friend used, which was not nearly as green as his original wheel:
                          Make your wheels look like they just rolled out of the factory with this spray wheel coating. This eliminates the need for expensive custom paint mixing and greatly simplifies the restoration process by providing spray-gun results without the hassle and mess of a spray gun or the need for an air compressor.
