So what is the most practical way to check for proper ride height and what should it be for a 69?
My original rear spring was sagged so I bought a good used one from what I was told was from a early mid-year. I cleaned it up and put new liners in, did the final torque to the diff housing with the weight on and used new rubber bushings so everything should be to original spec now. However now the rear sits about 1 7/8" higher in the rear than the front as measured at the wheel well lips.
The car was sagging in the rear before and now it looks way too high. I've read that if I drive it that it will settle but I want to do my alignment before I start to drive it and I need the right height to be at least close for this. I've check the J and K dim as per the AIM but I don't trust them as my floor isn't true enough for an accurate measurement. Regardless, J seems close and K is too high.
So for checking ride height I would think that a measurement from the wheel well lip to the floor would seem like a reasonably accurate way to check ride height. If so what would be the measurements?
Is there any way to "settle" the rear spring? I'm actually thinking of taking it out and greasing the liners or even intermixing some of my original leafs to obtain the correct ride height. There must be better way than to just drive it and wait for it to settle.
