64 ignition switch replacement - NCRS Discussion Boards
  • Gary B.
    • February 1, 1997
    • 6979
    Re: 64 ignition switch replacement
    Originally posted by Harry Sadlock (38513)
    Think I got mine with one hole from Pete Lindahl.
    • Harry S.
      • July 31, 2002
      • 5258
      Gary, I just got the chrome bezel. I also used Pat's Lock's in Maryland, but he sold the business and all his inventory.
      • Gary B.
        • February 1, 1997
        • 6979
        #18
        • Ralph P.
          • February 1, 1990
          • 253
          #19
          Richard, here's a seller I used for a correct 67 switch...... He may be a source for a 63... thomas-j-sestak-autoparts ( Ebay)
          • Gary B.
            • February 1, 1997
            • 6979
            #20
            I’ll give a 2nd vote of support for Thomas Sestak. I’ve purchased 10 to 20 lock and key items from him over the years and I’ve always gotten what I expected. He’s very knowledgeable about locks and keys, and he knows what’s correct in terms of original vs reproduction. If you communicate with him, tell him you’re looking for items that will pass NCRS judging. Not everything he sells will pass judging, but he knows what will and what won’t. He’s not an NCRS devotee, per se, but he will honestly answer any questions you ask him.
            Gary
            • Richard F.
              Infrequent User
              • November 12, 2007
              • 26
              #21
              i checked ebay. the only switch listed is the replacement like i got. i think i will try my old switch with the raised woodruff -like pin that fits the rear of the dash to keep from spinning.
              thanks for all the help guys.
              dick
              • Leif A.
                • August 31, 1997
                • 3607
                #22
                Richard,
                Did you give David Sokolowski a call yet? He'll have what you need.
                Leif
                • Harry S.
                  • July 31, 2002
                  • 5258
                  #23
                  This NOS part is up on ebay.... https://www.ebay.com/itm/Corvette-11...cAAOSw5Jdf1jPg
                  You can not see the number on the part. I sent the seller an email, the reply was. The auction says it a 650. Unless he shows a picture you can't prove it.
                  There are some 1116635 and 1116650 USED on eBay but NOS it the way to go.
                  • Richard F.
                    Infrequent User
                    • November 12, 2007
                    • 26
                    #24
                    leif:
                    not yet. will do so this week. i'm just playing with the original housing now that i've cleaned and lubed it.
                    thanks for the referal.
                    richard
                    • Dan B.
                      • July 13, 2011
                      • 545
                      #25
                      Another angle (for those who like to work on stuff), there are many other GM cars of the era that had similar type switches that could be harvested as good donors for the inside wear parts if you want to save your original 635 case if something is broken.
                      • Richard F.
                        Infrequent User
                        • November 12, 2007
                        • 26
                        #26
                        i checked ebay for 635 switches and found 2, each is $150. they are correct castings. i finally got off dead center and cleaned,lubed it. new lock cylinder works well. so i reinstalled it and it seems to work ok. now i've got to find the accessory wire(brn) in the harness, as the previous owner didn't for some reason. the circuit diagram has several brown wires so i'll be upside down under the dash for a while looking for it. it will take a few pain pills after the fact to recover..old injury to back keeps popping up. i hope to close the book on this one. will advise.
